Change coordinates from a list points
Hi everyone, I need help with a modification to my point lists.
I want to modify the positions of my points in X and Z based on a pre-existing list of points. Is there any way I can add values to my points to generate new points?
I want my diagonals to not intersect each other but instead have a distance between them so that when I import it, it appears correctly modeled.
Yep, a co ordinate is jusy a number so you split the point with point.x , point y , and point z. Make the additions or subtractions to whatever vector then merge them back together with pointbyxyz node.
This node may help: Dynamo Dictionary
Note the vector would likely be formed by the original points and the new points.
