Change color of a linestyle
@3Pinter Looks good. Are you running Dynamo for Revit?
off-topic (oh wow, printscreen + ctrl-v works!)
This is downloaded from dynamo website since the original 0.9 installed with revit 2017 causes instability for the 1.3 version.
But the color picker is missing as you see :sweat_smile:
Hmmm seeing this now,
@Konrad_K_Sobon,
Nice, color picker aside, your script does the trick.
thanks!
the color picker is from a package called UI++ Since it was merged into core Dynamo so it will be available in next release if I am not mistaken that will be Dynamo 2.0
your issue with the archi-lab package should be resolved if you download the latest. I removed that dependency on Dynamo 2.0
Hello Konrad, I’m attempting to use this Python script to accept a list of strings instead of just one string - but I get an error when I feed a list of strings into it. Would there be a simple adjustment to make it work on a list of line type names? Thanks for any help you’re able to provide.
I have turned the Python code above into the C# node and added it to archi-lab.net packages for convenience. It works like this now.
You can get the node by simply downloading the package from Package Manager.
Cheers!
-K
Amazing, Thank you so much Konrad.
