Centre of Gravity for Rebar in Revit
Hi, I am new to Dynamo and would like to know how I can get the Centre of Gravity on my model.
Hello, please post your first attempt.
Hi Simone,
I have only tired what I have seen online and they don’t seam to work. I don’t even know where to start if I’m honest.
So, what have you seen or tried that you have seen online? Can you post links to these examples? Have you searched the forum for examples?
What are you trying to do with the centre of gravity of the rebar? Is it just wall footings or isolated column footings? The more info you can share the greater the chance someone will help you or direct you.
Please also see - How to get help on the Dynamo forums
If one had the location line as a single continuous polycurve, one could get evenly spaced points along said polycurve, and build an average point from those values to get something close.
This works only because the shape’s mass is evenly distributed along the curve, but resolution will matter a good bit.
