Hello everybody,
I have recently started using dynamo and would like some help. I would like to know if there is any algorithm that allows me to determine the center of the stiffness of a structure? thanks to anyone who will answer me
Hi @dom.cinquegrana ,
Could you maybe explain/ show with pictures how this is normally determined without using Dynamo?
Thanks for the reply @Daan
I have to perform an analysis where I have to calculate the moment of inertia of each pillar of the structure and add them
Okay, so i assume you want use the Revit Parameter which contains the Inertia value, getting those values is quite easy.
Could you maybe explain how you would normally determine the center of stiffness?
