Ceiling Height Spaces
I am trying to use the raybounce node to read the ceiling height in the model and assign the correct height to the limit offset parameter but I Keep getting a null value, any help would be really appreciated?
I would first work on removing those null’s from your lists. After you’ve removed the nulls, then move on to the filtering part. Can you share what the error is you’re getting on the Element.set parameter?
Thanks Patrick, I managed to resolve it myself with rounding the number and chopping it in to sublists
