Can't cut Door family in plan
Hi everyone,
I create the Door Family and load it into the Project. In the 1FL plan, the Door Family created doesn’t show the cut Frame like this picture. Even I already changed the Cut Level of the View Range.
When I create Door Family, I separate each part of Family to part such as: Louver Family, Panel Family and Frame Family… and then, I insert them into one Family. This is a reason that my Door Family can’t show the cut frame, the cut panel… in the plan.
Please help me!
Could you please drop here rvt file.
Door.rfa (1.4 MB)
This is my door family that i create.
Thank you!
@hoale_kts
It was visibility off in family, make sure you switch it on:
This is a door plan in the family file, I have already marked visible bar.
door%20family
This is a plan after inserting into the project
door%20cut
To Mr. Kulkul,
I have corrected my mistake. Thank you so much!
sorry, I don’t found/understood the solution to this issue that i’m suffer too
