Dear Dynamo Specialists,
I would like to get the VOID in the Family of the door. See first picture door Family.
The big question is to get the area op the door opening.
This picture is the door opening created by the void in the door family.
When I open the door family you can see the “Doors (Void)”
How can I get the area, geometry or element of the VOID in the project where this family is loaded?
@rlandkroon , hi
You can solve this with parameters a*b … store the result in an Parameter …
KR
Andreas
solution by analyzing cut lines geometry (hidden lines)
import sys
import System
clr.AddReference('RevitAPI')
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append('%sIronPython 2.7Lib' % pf_path)
import itertools
def get_CutLinesDoor(e):
lines = []
opt = Options()
opt.IncludeNonVisibleObjects = True
geoSet = e.get_Geometry(opt)
for g in geoSet:
if isinstance(g, GeometryInstance):
for gi in g.GetInstanceGeometry():
if isinstance(gi, Line):
if gi.GraphicsStyleId == ElementId.InvalidElementId:
# get horizontal Lines
vect = gi.ComputeDerivatives(0.5, True).BasisX
if abs(vect.Z) < 0.001:
lines.append(gi.ToProtoType())
opt.Dispose()
return lines
e = UnwrapElement(IN[0])
out = []
cutLines = get_CutLinesDoor(e)
cutLines.sort(key = lambda x : x.StartPoint.Z, reverse = True)
for idx, (key_, group) in enumerate(itertools.groupby(cutLines, key = lambda x : x.StartPoint.Z)):
if idx == 0:
top = key_
top_loopCurve = DS.PolyCurve.ByJoinedCurves([x for x in group])
bottom = key_
DSSolid = DS.Curve.ExtrudeAsSolid(top_loopCurve, Vector.ByCoordinates(0,0,-1), abs(top - bottom))
out.append(DSSolid)
OUT = out
