Hello everyone,
I’m new to the forum and I would really appreciate any help with an issue I’m currently facing.
I am working on a Dynamo workflow using a Python Script node to automatically create an Alignment in Civil 3D 2025 based on input parameters such as point coordinates, radii, etc.
I am testing with the input data shown in the Excel screenshot.(This alignment includes line, clothoid, and circular curve segments.)
I am using the Python code included in the attachment, but I have not been able to successfully create the clothoid segment.
I have tried using the methods AddFixedSpiral, AddFloatSpiral, and AddFreeSpiral, but none of them worked in my case.
Here is the reference link for the methods I have tried to use:
https://help.autodesk.com/view/CIV3D/2025/JPN/?guid=90669160-1fe2-7af6-eec0-a47a55c1ca50
If anyone has experience or advice regarding creating spiral (clothoid) segments using Civil 3D API within Dynamo, I would really appreciate learning from you.
Thank you very much for your time!
Python Script:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
import Autodesk.AutoCAD.ApplicationServices as appsvc
import Autodesk.AutoCAD.DatabaseServices as dbsvc
import Autodesk.AutoCAD.Geometry as geom
import Autodesk.Civil.ApplicationServices as c3dappsvc
import Autodesk.Civil.DatabaseServices as c3ddbsvc
fW = dbsvc.OpenMode.ForWrite
adoc = appsvc.Core.Application.DocumentManager.MdiActiveDocument
cdoc = c3dappsvc.CivilApplication.ActiveDocument
doc_lock = adoc.LockDocument()
try:
tr = adoc.Database.TransactionManager.StartTransaction()
label_set_name = 'MLIT_20-線形ラベル セット'
style_name = 'MLIT-線形スタイル'
layer_name = '0'
# Alignment Creating
ID_align = c3ddbsvc.Alignment.Create(cdoc, 'Alignment', '', layer_name, style_name, label_set_name)
align = tr.GetObject(ID_align, fW)
# Points Creating
P0_EP = geom.Point3d(-17.0440, 17.6170, 0)
P1_TS = geom.Point3d(14.2350, -28.3090, 0)
P2_SC = geom.Point3d(44.0580, -68.3980, 0)
P3_CS = geom.Point3d(90.9220, -107.4540, 0)
#P4_ST = geom.Point3d(135.7310, -129.5600, 0)
#P5_TS = geom.Point3d(168.3160, -143.9810, 0)
#P6_SC = geom.Point3d(213.1250, -166.0880, 0)
#P7_CS = geom.Point3d(262.4570, -207.9940, 0)
#P8_ST = geom.Point3d(291.5180, -248.6380, 0)
#P9_EP = geom.Point3d(316.1330, -286.2840, 0)
# Segments Creating
sm0 = align.Entities.AddFixedLine(P0_EP, P1_TS)
sm1 = align.Entities.AddFixedCurve(sm0.EntityId, P1_TS, P2_SC, 200.0, False, False)
sm2 = align.Entities.AddFreeSpiral(sm0.EntityId, sm1.EntityId, 100, SpiralParamType.AValue, SpiralCurveType.InCurve, SpiralType.Clothoid)
tr.Commit()
finally:
doc_lock.Dispose()
OUT = align.Name
1128_Test.dwg (993.1 KB)
