i create the dimensions for the elements using “Dimension.ByElements” node.
And tried creating dimensions for new elements but the Dimensions which are created are deleting.
i have tried baking the elements with beaker package but it didn’t work…!
So, i got an idea that if we copy the dimension at the same location, then one will be deleted and one will be there.
how can a copy the dimension ?
Thanks in advance.
With Best Regards.
hello @mrathnakar, happy birthday
Can you post your dyn file or a screenshot in order to see what’s going on?
Hi @mrathnakar
For Dimensions related tasks you can always refer Genius Loci package for better results
thanks have a nice day
This is an element binding issue. See this post for a detailed breakdown.
Solved using Genius Loci Package.
Used Dimension by reference instead of “Dimension.ByElements”
Thankyou @dineshsubramani
With Best Regards.
you deserved it, Brother, @Alban_de_Chasteigner
Can i find any node in Genius Loci Package for creating floor finish using outline type and level.
Thank you.
