Can not rename a family type
Hi All,
I have followed all other advise and can not work out why I can not access a walls name by using Element.Name- I get an AttributeError:Name
In the script below, I am simply passing in a Categories Node: Walls. I can successful output the walls before the for loop starts, but the error happens when I try and call name.
Common Language Runtime module
clr.AddReference(‘RevitAPI’)
Revit and Dynamo module
from Autodesk.Revit.DB import FilteredElementCollector, Family
collector = FilteredElementCollector(doc)
Option 02, pass them in from dynamo (ensure you unwrap them before using them)
category_input = UnwrapElement(IN[0])
collected_walls = collector.OfCategoryId(category_input.Id).ToElements()
argument assigned the IN port
rename = IN[1]
core data processing
type_name =
for element in collected_walls:
for idx, searched in enumerate(collected_walls):
if searched == element.Name:
element.Name = rename[idx]
type_name.append(element.Name)
TransactionManager.Instance.ForceCloseTransaction()
return assigned the OUT port
OUT = collected_walls
It doesn’t look like you are getting the WallType from the walls you have collected.
wallTypes = FilteredElementCollector(doc).OfCategoryId(catId).WhereElementIsElementType().ToElements()
for wt in wallTypes:
    wt.Name = rename
Hi @SeanP, Do you dont call .Name from the element itself, do you need to isolate the element and then do .Names
Because in the example you give, I would have thought it would be wt.Names, as you are isolating them in the loop?
You are correct, I had a typo there. I have edited the response.
You can use a Package DynaMEP
@SeanP
Thankyou, the answer was that I was not bringing in ONLY types of the element that matches my parameters as you correctly mentioned- I didn’t know about this.
Thankyou very much
