Can Dynamo interface be customized?
Anyone:
Is there any option to adjust the interface for Dynamo? The darkish grey lettering on the darker grey background for the tabs, menus, and tools can be very hard to see adjacent to the bright white of the 3D work area. It doesn’t even match the graphic for the Revit interface.
Are there any skins for Dynamo? I am sick of grey on grey - some folks think it’s stylish, but it is profoundly unimaginative, remarkably timid, and very hard to see - and besides, why such a dearth of choice? We can customize so much in our computing lives, so why do we have only light grey or dark grey from autodesk?
thanks very much
I guess you could hack it using ViewExtensions
Entirety of the color schema for Dynamo can be customized from the XAML settings file here:
C:\Program Files\Dynamo\Dynamo Core\2\UI\Themes\Modern
What you are looking for is the DynamoModern.xaml file and all of the color values that start with “#”.
Superb, thanks very much! I will have a look … would it be safe to make adjustments to the colors (perhaps my company colors), then save the .xaml file, then offer that to others as a ‘skin’ or a theme?
Thanks again
Sure. I don’t see why not. If people want to customize their colors then who am I to tell them not to.
@Konrad_K_Sobon - do you know what is the line number or term used for the workspace color? I tried changing the #FF… colors but couldn’t find specifically “workspace color”. My workspace is still white :confused:
Change to Color x:Key=“WorkspaceBackgroundHome”>#A1A1A1</Color
in DynamoColorsAndBrushes.xaml for grey background.
Thanks @Vladimir. It’s my understanding that Dynamo for Revit 2021 cannot be customized, which is the version I alluded to. Is that correct? I been able to swap colors for R19 but R21 seems impossible, after trying to adjust most of the hex code colors in all the .xaml files :face_with_head_bandage:
Didn’t notice any problems in 20,21,22,23. Just edit and save DynamoColorsAndBrushes.xaml of Dynamo folders (just find all DynamoColorsAndBrushes.xaml on your “C” drive).
Thanks @Vladimir for clarifying. It’s now working for me. I did a search of the files on my pc and realized I had missed the R21 and R22 folders.
One more path to our piggi bank ))
C:\Program Files\Autodesk\Revit 2022\AddIns\DynamoForRevit\UI\Themes\Modern
File:
