Camber StructurePlanLabel.ByStructure Reference Alignment
Running into an issue with the StructurePlanLabel.ByStructure node in the Camber package. I have a structure label for a structure at the intersection of two alignments. The label reads the reference alignment of the structure (Sta. 13+74.59, SWS Line 1 in the attachment).
The other alignment is pulled using a reference text component in the label in order to pull the station and alignment name of SWS Line 1A. So when I assign the alignment in the properties window, the alignment name (SWS Line 1A) shows up but the station shows three question marks ???
Label works fine if I was to manually place on the structure and then change the alignment in the properties window. For whatever reason, it seems converting to a Camber objects conflicts with Reference Text Objects? Any help would be appreciated.
