Hello all,
I want to create a solid from a revit profile (it is just a rectangle). Every time that I run the script after the node ‘BoundingBox.ToCuboid’ Dynamo crashes.
The python script that I use in order to get the curves from the revit profile is the following :
Import ToDSType(bool) extension method
Import DocumentManager and TransactionManager
Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
type = UnwrapElement(IN[0].Family.Name)
name = UnwrapElement(IN[0].Name)
family = UnwrapElement(IN[0]).Family
TransactionManager.Instance.ForceCloseTransaction()
famDoc = doc.EditFamily(family)
famCollector = FilteredElementCollector(famDoc)
sketch = famCollector.OfClass(Sketch)
for i in sketch:
cArray = list(i.Profile)
cArray[:] = [[Revit.GeometryConversion.RevitToProtoCurve.ToProtoType(y, True ) for y in x] for x in cArray]
OUT = cArray
Any idea?
Thank you!
