BooleanOperationsUtils is not defined
Thanks in advance for every input.
I tried to use
BooleanOperationsUtils.ExecuteBooleanOperation(arg1, arg2, BooleanOperationsType.Intersect)
to evaluate if a solid gets intersected by another solid. (Later i want to use it to compare the whole list)
Do i miss some necessary imports in PythonScript, or what could be the problem here?
Input Parameters are 2 non-nested lists with solids as items.
import sys
clr.AddReference('RevitAPI')
rooms = IN[0]
gds = IN[1]
a = rooms[0]
b = gds[0]
val = BooleanOperationsUtils.ExecuteBooleanOperation(a, b, BooleanOperationsType.Intersect)
OUT = val
@d.feyerer Try adding from Autodesk.Revit.DB import *
Thank you for your answer, first error wasn´t shown again.
But now i have another error message, which quite confuses me:
“Expected Solid, got Solid” → ?
What does that mean? Are there different Types of “Solid”?
I used Object.Type node and it shows, that the items of both lists got type:
Autodesk.DesignScript.Geometry.Solid
CUSTOMWriteSlabTagsToRooms_adaptions.dyn (148.8 KB)
Yes: You are inputting a Dynamo Solid from its ProtoGeometry library where as the Revit API BooleanOperationsUtils.ExecuteBooleanOperation method expects a Revit API Solid. Try calling ToRevitType() on the Proto Solid, just don’t expect very reliable results as it will fail conversion often.
@Thomas_Mahon
I´ve found a wiki entry on github.com, where you have described the transformation from Dynamo Geometry to Revit GeometryObject instances ( Python 0.6.3 to 0.7.x Migration · DynamoDS/Dynamo Wiki · GitHub)
I managed to transform the Dynamo Solids to Revit Solids with this approach (for one item). I am actually testing the approach if it produces stable results.
import sys
clr.AddReference("RevitAPI")
rooms = IN[0]
gds = IN[1]
a = UnwrapElement(rooms[0])
a2 = a.ToRevitType(TessellatedShapeBuilderTarget.Solid, TessellatedShapeBuilderFallback.Abort)
a3 = a2[0]
b = UnwrapElement(gds[0][0])
b2 = b.ToRevitType(TessellatedShapeBuilderTarget.Solid, TessellatedShapeBuilderFallback.Abort)
b3 = b2[0]
val = BooleanOperationsUtils.ExecuteBooleanOperation(a3, b3, BooleanOperationsType.Intersect)
OUT = val, a3, b3
