Come take a read of our latest blog post by @Karam_Baki on The Red Sea International Airport, designed by Foster and Partners and Jacobs, where he uses dynamo to pioneer BIM efficiency and create incredibly data-rich, complex ceiling panels to 2mm precision
The curved form and plan are intended to emulate the desert landscape and will be characterized by five dune-like pods arranged around a central drop-off and pick-up space.
The topic with the single core Transaction is intresting, this problem as old as revit. So to “deligate” the task to a core … is this only possible with cero touch.
is there any repository (github) to investigate? or is only C# able to handle transactions by core?
In this particular case, Karam has a super powerful machine and simply opened up 10x instances of Revit, dedicated a single core to each instance and then ran portions of the output (Generating SAT files for later import) on each one.
The problem space is real for sure - and we’re looking at ways to make this even better Some hints around a local service mode and “Engine” node that’s in the works allowing users to run different Dynamo graphs in different threads.
