Blockreference not being placed, uniform scale warning
when trying to place blocks the following warning returns “the block requires uniform scaling”
can’t find the issue, the block is set to scale uniformly.
never mind, renamed the block and now the warning is gone. :exploding_head:
Checking the scale of the coordinate system vectors can also fix this. They can be scaled to have differing values on the X, Y and Z axis.
nice additional information, thanks
I think this particular node might have a bug. I’ve found it to be inconsistent when that warning comes up. It actually seems to work a little more consistently if the block definitions are set to NOT have uniform scaling.
it’s a hit and miss, don’t know if it’s block, drawing or node related
I have made the same conclusion this must be a bug, and a very annoying one
