Hi!
I have played around with PathReinforcement.CreateByCurveAndShapeCode from BIM4Struc.Rebar package and I am running into a few issues.
- No matter what bar length I specify, Dynamo will always model 2000mm long rebar.
- If you select “None” for rebar hook type the script won’t work. So when I want to model straight bars I will still need to specify some kind of hook even though I don’t actually want a hook and will end up specifying M_00 as bar shape (M_00 is a straight bar shape).
I am not so concerned with #2, but I would like some help/suggestions for issue #1. Does anyone else have this problem?
Thanks.
