The problem
The editor inside the Python Script node gets the job done, but it’s pretty bare bones. Writing anything more than a few lines means bouncing out to VS Code (or guessing at method names), and there’s not much help when something goes wrong.
What we’re considering
A better, more modern code editor for our script-based nodes, potentially built on something like Monaco (the editor that powers VS Code). Think better syntax highlighting, autocomplete, inline errors, find and replace, minimap, all that good stuff.
Concept image, not final UI.
This is under consideration only. No timeline and no commitment yet, and we want your input before we decide if and how to do it.
How you can help
- What frustrates you most about the current script editor?
- Which features would you want first (autocomplete, inline errors, multi-cursor, themes, something else)?
- Do you mostly write code in Dynamo, or in an external editor and paste it in?
- If we also do a C# Script Node, would you expect the same editor there?
Reply below or vote if this matters to you.
Safe harbor statement
Roadmaps are plans, not promises. We’re as excited as you to see new functionality make it into the products, but the development, releases, and timing of any features or functionality remain at Autodesk’s sole discretion. These roadmap updates should not be used to make purchasing decisions.
