Hi all,
I was wondering, what is the best approach to program a CASE ?
If you see my graph it’s pretty heavy
FYI : What i’m attempting to do is a specific rotation depending of the type that is in the description of the structure part
Hi all,
There’s some pretty simple DesignScript syntax that you can use in a Code Block.
Generally:
conditionToCheck ? trueValue: falseValue
Example:
You can nest these statements, but eventually it might become unreadable. At that point you might consider just writing some if-elif-else
statements in a Python node.
Sweet ill.dig into it
And find out how to do this with strings
Rather than it statements, try a dictionary.
Hard code it once with all the possible names as keys and the rotation as value, then pull the values using the description and you’re all set.
String.Contains is not the best function to use. When you search for “T”, is it also found in “POTEAU INDENCIE” and “REDUIT” and more. It is better to use a function which will always give the desired result and that you feed it the values which you are certain about that this will happen. Maybe with String.StartWith, but when you have descriptions that start with “T”, it will also give false results. In you example, you better use the == node.
When looking for a series of texts, you can combine all instead of duplicate the nodes for each search string.
In this example you have a list of descriptions and you are looking for 4 values to be found. If you don’t set the level, you will compare one list to another list, where indice 1 is compared with indice 1 of the other list, and so on. If you set the second list to level 1, each item of the second list is processed apart, which result in (in the example) 4 lists of bools. The first list compares indice 1 to the whole other list, the second list compares indice 2 to the whole list, and so on.
Then it is not difficult to calculate the rotation:
If you want to combine this all in one Code Block, using Zachri’s tip:
Here you set the level of the search texts with the cartesian replication notation <1> at the end of the variable ‘search’.
Rethinking, I am not sure if my example will help you, because you create new lists with lists. Would be hard to work back to the original list.
A better approach is this:
Now you look for a text equal to one OR another.
But in some cases it must not be 0.0 but 180.0. You can replace one of the values with another structure of “a ? b : c”:
No thought to the dictionary method?
hi, another variation
cordially
christian.stan
Instead of asking if a is one of the options, ask if a is in the dictionary’s keys.
List.Contains(dict.keys(),a)?dict[a]:0;
always happy to learn, thanks for sharing
cordially
christian.stan
Woaaa !
A lot of action during weekends !
Thanx a lot everyone - Ill test out these approaches and this thread is going to be usefull to help others for diffrent approaches for simple stuff in Dynamo.
Alrighty all
I’ve did the nested if’s inside another :
And it works !
I’ve tried the dictionary too but the IF method i used is a bit more familiar for me
Thank you a lot for these solutions !
I was wondering though
If i want to use a CASE to redirect the workflow of my code
How would be the best approach ?
Let say, if the description matches “T” i want it to follow a different path ?
Branching is a little challenging in a visual programming environment
The ScopeIf
node could be an option. Example here:
