i am trying to batch plot pdfs using revit 2025 and crumple nodes but having issues with the nodes, everything runs fine in revit 2024 but nothing in 2025, does anyone know of a way or which nodes are best to use with revit 2025,
Have you looked into the pdf export button within revit as this may fulfil what you want to do, in 2025 it can also be selected to run in the background while you continue to work.
Help | Export a PDF File | Autodesk
I will add that i dont know of a node that will do it for you.
thanks for the information, that way did work as i had already set up a dynamo script to put the ISO drawing number into a parameter, i didnt know this way was possible, thanks again
after some digging i have found out the crumple export to pdf node works fine its just the print to pdf node that does not work yet
