Is it possible to manipulate the coordination review in Revit? I want to be able to batch set actions as sometimes there are a lot of rows where I want to do the same action for all of them. This screenshot is an example where I would want to change.
you don’t need niether Dynamo nor API, you just have to select multiple lines using the Shift key, and then apply the same option to all of them
Well… I know… this only works for a single RVT file when it’s open. You can’t use it for a bunch of files…
