Bake Elements
Hi there,
I’m looking for a way to execute two times the same script without delete the previsous elements created with Dynamo.
I was trying using a node called Bake elements. The thing is that when I use this node, the script doen’t work properly. Without the bake elements node, evrething is working as expected.
Thks
Manel
I’ve tried to do it via Dynamo player, but still doen’t work. Dynamo delete previous elements.
Revit2018+Dynamo2.0
Cheers
Manel
I’ve found a solution here:
This is the Python code in order to place families By point and By Level:
Cheers
Manel
