You still didn’t try changing this… Well… i am out.
Thank you very much for all your efforts
CLOCK WORK 2.12.3
bimorphNodes 3.03
dynamoironpython 2.4.0
revit 2024 I have also Revit 2025 can you share with me your dynamo package versions
Thank you very much for all your efforts.
I will try to solve this issue it seems there is something wrong in my packages.
FamilyInstance.ByCurve may require IronPython as @bvs1982 has implied. Make sure you have the correct version of 2.7 installed. You can also “remove” the contents of the custom node and run them directly in your graph (probably just a python node) to see what warnings you get there.
as @bvs1982 has implied. I just use the correct package version and its work correctly now.
