I would like to control dynamo from an external program. The program would need to be able to:
<ul style=“list-style-type: undefined;”>
Is this possible? Through an API or through a batch file process.
Thanks, Patrick
Thanks, Patrick
I suggest it be called Dynamonamo…
The “Run dynamo, close dynamo, Open dynamo, read geometry” part could probably be done by opening and closing a transaction in revit.
This editor is doing strange things. I will try again…
The program should
(Steps 3 and 5 are somewhat optional as they could also be achieved through reading and writing files. )
Thanks, Patrick
Thanks for teh suggesting Joseph. But I am trying to do this from outside all the autodesk ecosystem. I want to do it from a program that I am writing.
this is possible, I’m not sure about the simplest way to get it done, but you should look at the tests folder on the github repo, these tests control dynamo , open files, run the graph etc.
