Auto dimension pipes/sprinkler
Hi, I want to dimension ‘center to center pipes’ and ‘center to center walls and pipes’. The walls are in a linked model that i got from the architect" . I have searched the forum but much of this is outdated. However, I have found one that should work, though this is for ducts. this scrit was made by @Alban_de_Chasteigner from this topic Auto dimension MEP - Revit - Dynamo.
My goal is to dimension those pipes/sprinkler that are placed on different angles. i already got some help by @sovitek
@sovitek could you please share you script from the other post? i would appreciate it
here is an example and be sure you have the right ironpython installed as well should be 2.7 version 2.5 if 23-24 and 3.2.1 if 25
i will look at it ang get back!
hi @sovitek, i have tried the script. instead pf pipe, i have changed it to “sprinklers” but can’t make it work. im using rvt 2024 here and im in a sheets view.
Here is an example for linked walls and sprinklers
is it possible if you post the script so i can run it and see? :slight_smile:
sorry i have just close it down without save, but it should be possible follow the image and good for practice :wink:
hmm, are you doing this on a sheets view?
not sure i understand, didnt know we could dimension in sheet [guess you mean on viewport on a titleblock], only if component is placed there maybe ex titleblock itself, 2d object etc…so im not familar with that workflow :wink:
yes, on a viewport
dont think its possible even manuel you will need activate the viewport…viewport it just a graphic thing from the view and dont have any dim reference
yes you right, i need to activate the viewport and then measuring it. but is it possible on work view?
yeah thats what i try show you :wink: :wink: try play around with it and you probably need some modify so it fit your situation, it was just an example from my side :wink: :wink: and yeah reference can sometimes be a jungle :wink:
ok i understand, why are those error showing up when i run it?
