You usually shouldn’t have consecutive Python nodes as it is extremely inefficient.
The intent is to use these methods to assist in authoring the code, often one after the other.
object = IN[0] #get an object however you like - in this case I'm bringing it in from the Dynamo environment
whatCanYouDo = dir(object) #get a list of what you can do with the object using your current imports
OUT = whatCanYouDo #return the list of what you can do with the object into the Dynamo environment
#### after running the above, change the ####
#### "Method" here to one of the items ####
#### in the output, and uncomment the ####
#### line to learn about it, such as the ####
#### inputs, or any other documentation ####
#documentation = object.Method.__doc__
#OUT = documentation, whatCanYouDo
So run that code, find something you like about the object, and then modify the documentation = object.Method.__doc__ line to be documentation = object.**SomethingFromTheCurrentOutput**.__doc__, and uncomment the last two lines
