Attribute Error on Archi Lab Node
I am trying to change utilize the “Set BuiltIn Parameter” Node from Archi-Lab in Revit 2023
This is the python script inside of the code block.
# Copyright(c) 2019, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
clr.AddReference("RevitAPI")
import System
paramName = IN[0]
if not isinstance(IN[1], list):
        elements = [IN[1]]
        elements = IN[1]
if not isinstance(IN[2], list):
        paramValues = [IN[2]]
        paramValues = IN[2]
def GetBuiltInParam(paramName):
        builtInParams = System.Enum.GetValues(BuiltInParameter)
        test = []
        for i in builtInParams:
                if i.ToString() == paramName:
                        test.append(i)
                        break
                        continue
        return test[0]
try:
        errorReport = None
        bipName = GetBuiltInParam(paramName)
        for i, j in zip(elements, paramValues):
                param = UnwrapElement(i).get_Parameter(bipName)
                if param.StorageType == StorageType.ElementId:
                        id = ElementId(j)
                        param.Set(id)
                        param.Set(j)
except:
        import traceback
        errorReport = traceback.format_exc()
if errorReport == None:
        OUT = IN[1]
        OUT = errorReport
When I run the script, the error it get is;
File"“, line 51, in
File”", line 40, in GetBuiltInParam
Attribute Error: ‘int’ object has no attribute ‘ToString’
I have spent a great deal of time searching attribute errors and anything else it could be, I am completely out of ideas. Could someone please help me?
Thanks!
are you sure the parameter you have plugged in is a built in parameter? BuiltInParameter Enumeration (revitapidocs.com)
if its not in the list there the script will stop at that line which is what seams to be happening.
or the value there is null or emepty
Yes I am sure, I am using VIEWPORT_DETAIL_NUMBER, is there a reason this one would not work while looking at a sheet of details, does the detail have to be active?
hi @markb43
It’s a Python.Net issue, read this
in particular
Thank you! That fixed part the issue, but now created a new one. Now I have an error that reads
File “<string”>, line 65, in
TypeError: No method matches given argument for get_Parameter: (<class ‘str’>)
According to the article you provided this is something that should have been fixed?
Try directly with the BuiltInParameter
example
    param = UnwrapElement(i).get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER)
    param.Set(j)
