Attach Topography to Floor
Yes
With the below definition you should get similar results without splitting
Topography-3.dyn (23.1 KB)
Topography-3
Topography to Polysurface code (included in the above definition)
iA=List.GetItemAtIndex(T.Mesh.VertexPositions,T.Mesh.FaceIndices.A);
iB=List.GetItemAtIndex(T.Mesh.VertexPositions,T.Mesh.FaceIndices.B);
iC=List.GetItemAtIndex(T.Mesh.VertexPositions,T.Mesh.FaceIndices.C);
TopoSurf=PolySurface.ByJoinedSurfaces(Surface.ByPerimeterPoints(List.Transpose({iA,iB,iC})));
Hi Vikram,
Is there anyway to run this graph using multiple floors, that have slab edge edits?
I am a landscape architect and we commonly use floors with slab edge edits to model site.
@asargeant Should be possible, though I don’t completely recollect all aspects of the above workflow.
Please try selecting multiple floors and post your results here along with files and error screenshots.
I think the problem might no be the fact I tried to do two floors but that one of them has modified interior points.
Hi all,
First, thanks for this super useful thread. As a beginner with Dynamo, I have been trying to attach the topo to a surface using Dynamo for a long time and this thread has been of great help!
There is one last step I would like to add to my script : instead of offsetting the perimeter of the floor, I would like to be able to control the angle of the slope of the fill up/excavation. That way, regardless, of the height difference between the road and the topo, the angle of the slope will be the same.
I would be grateful if you guys had any tip to do that.
Thanks in advance.
The below definition, besides being a slightly improved version of the earlier definition I’d posted, has a slope angle parameter
Topography-4.dyn (34.6 KB)
And the result in Revit is something like this …
Hi Vikram,
Thanks a lot for your script and your time. Let me go through it and I will come back to you if I have any question!
Hi Vikram!
Sorry for the delay in replying.
If I am not mistaken, the angle in your script controls the offset of the projected polycurve on the plan created below the topography. However, it does not control the angle of the slope between the road and the topography.
See the image below: I am trying the have all the slopes around my object to have a controllable angle. At the moment, the closer the topography from my object, the flatter the slope.
I appreciate your help in that matter!!
Dynamo-Image01|690x435
I hope this could help
The one below should …
Topography-5.dyn (35.2 KB)
Topography5
Hi guys,
very interesting thread, i tried the script but only one face of the floor has been connected by the topo, do someone have idea of the reason?
Hi, is it possible that it is related to the different heights of the floor border?
thanks
Hello! I am very interested in a solution to bring topo up to a walkway/surface like you have shown. I am running this in Dynamo and getting the error attached. Is there an issue within Revit if it is giving me this?
Following the thread. Am in the same situation now. I need to bring up the Topo to multiple floors.
This solution will have changed now that Revit uses TopoSolids instead of TopoSurfaces - what have you tried so far?
we’re still using 2021 so yah, still toposurface.
