All,
Do any of you know if there is a way (through nodes or python script) to associate a families parameters to a projects Global Parameters using Dynamo?
I have been using Orchid’s Parameter.Associate to associate nested family parameters to the host families parameters with great success but this obviously does not work in a project setting.
The end goal is to be able to select a titleblock and then have the graph associate the global parameters to the proper titleblock parameters.
Any ideas or thoughts would be super helpful!
Thanks!
Yes, it’s possible with AssociateWithGlobalParameter Method.
It’s just a bit tricky to get the correct parameters, but I got some help from an old post from @awilliams (Thank you!)
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
name = IN[1]
gp = IN[2]
#Get parameters from element
parameters = element.Parameters
myparam = []
#Get parameters with the input name
for param in parameters:
if param.Definition.Name == name:
myparam.append(param)
#Associate parameter
for x in myparam:
try:
x.AssociateWithGlobalParameter(ElementId(gp.Id))
out = "Success"
except:
out = "Fail"
OUT = out
This is just an fast example that works with one element at a time, maybe @erfajo can do a custom node for his Orchid package (and thank you very much for what have you done so far)
@lucamanzoni
My first try with this failed. Here is what I am seeing:
The warning text reads:
File “”, line 51, in
NameError: name ‘out’ is not defined
Here is a sample project I am using along with the graph included. The titleblock on the right is the one that is needing to be associated (the one on the left is already done).
P.S. @awilliams is awesome!
BTW I am thinking this might have something to do with your setup looking at a model element and mine looking at a titleblock instead of an actual modeled element. If I use the Select Model Elements node I am not allowed to select the titleblock at all. Using Data-Shapes I am allowed to but it doesn’t work.
Does the script need to be updated to accept annotation families?
I also wonder if maybe it is not seeing the parameters because they are type parameters and not instance parameters. If I run the titleblock family through the Element.Parameters node I don’t see any of the type parameters.
I forgot to mention that not all the Parameters can be associated with a Global Parameter. You can easily check in Revit if you have a small button close to the parameter (that’s how you would manually associate in Revit, without Dynamo).
The graph I posted was to associate instance parameters, if you want to change type parameters you need to use Family Types:
This works. I modified the selection process slightly so that the user can simply run Dynamo Player and select the titleblock without having to open up Dynamo. Here is the final result:
Thanks again @lucamanzoni
And this is one of the reasons Dynamo is so awesome. It’s not just the program itself…it is the community! You guys have made my week. When I finish cleaning up my graph(s) I will post a few samples of what I have been able to accomplish for my company and hopefully it may be useful for others.
Great, guys! I was looking time ago for associating Global parameters for title blocks parameters. Here’s the solution. Parameter.Associate was the node I needed. Thanks for Orchid package!!!
Bravo! I found this method to be super helpful!
This might be for another topic, and I’ll move it if it is, but is there a method to associate a global parameter to a list of (or multiple) family types?
Here is the link to the new post.
