I acknowledge this topic has been covered in other threads. I’ve read through a bunch of posts but i’m stuck and not sure what i’m misunderstanding.
I am trying to set the crop box of an existing elevation based on part of a room boundary with an offset. This should be functionally similar to the procedure described by Jeremy Tammik The Building Coder: Create Section View Parallel to Wall (typepad.com)
i’m working with this situation where elevations are not aligned to room walls
I’m trying to change this view’s CropBox from the default (red) to the wall (green)
From the posts i’ve read it seems like the procedure is supposed to go like this
create bounding box aligned to project origin and internal CS
update the transform with the view orientation components
transform.origin = midpoint of wall curve
transform.BasisX = view right direction
transform.BasisY = up (for a section view)
transform.BasisZ = view direction (towards viewer)
set the bounding box transform = to the transform
set the view cropbox to the new bounding box
when i snoop the unmodified view, some things don’t make sense.
the view origin is not located at the element or even in the view
if i measure this out to the ‘observed’ origin, i would expect (-143.486,-110.642,0)
so it looks like the view origin is just setting the Y coordinate?
and when i get the unmodified CropBox, it is not located at the UCS
I’ve tried two different procedures:
- using Dynamo
transform the target geometry to the Internal Coordinate System
i think this is where my error is. I’ve tried a couple different configurations, but it seems like i’m choosing the wrong point as the CS origin. My best results, which give the view in the correct orientation, but just in the wrong location, occur when i use the midpoint of the wall and set the Z value = 0
construct the bounding box
set the cropbox with Views.SetCropBox
dynamo geometry preview of the BoundingBox looks like this
- using Python
Here, i tried to follow more explicitly what’s written in JT’s post, but it gives a similarly incorrect result.
import sys
clr.AddReference('RevitAPI')
uidoc = DocumentManager.Instance.CurrentUIDocument
def tolist(input):
if isinstance(input,list):
return input
return [input]
views = UnwrapElement(IN[0])
points = IN[1]
cs = IN[2]
watch = []
# need to set the new crop box!
watch.append("view found, activate view")
t = Transform.Identity
t.Origin = cs.Origin.ToRevitType()
t.BasisX = cs.XAxis.ToRevitType()
t.BasisY = cs.YAxis.ToRevitType()
t.BasisZ = cs.ZAxis.ToRevitType()
t.Origin = XYZ()
t.BasisX = views.RightDirection
t.BasisY = XYZ.BasisZ
t.BasisZ = views.ViewDirection
minT = points[0].ToRevitType()
maxT = points[1].ToRevitType()
## I found this procedure included in a related post somewhere. i've commented it out to try and match
## the JT post about sections aligned to wall
#minpX = min(minT.X, maxT.X)
#minpY = min(minT.Y, maxT.Y)
#minpZ = min(minT.Z, maxT.Z)
#maxpX = max(minT.X, maxT.X)
#maxpY = max(minT.Y, maxT.Y)
#maxpZ = max(minT.Z, maxT.Z)
#vsBBmin = XYZ(minpX, minpY, minpZ)
#vsBBmax = XYZ(maxpX, maxpY, maxpZ)
vsBBmin = minT
vsBBmax = maxT
vsBB = BoundingBoxXYZ()
vsBB.Enabled = True
vsBB.Transform = t
vsBB.Min = vsBBmin
vsBB.Max = vsBBmax
vsBB.set_MinEnabled(0,True)
vsBB.set_MinEnabled(1,True)
vsBB.set_MinEnabled(2,True)
vsBB.set_MaxEnabled(0,True)
vsBB.set_MaxEnabled(1,True)
vsBB.set_MaxEnabled(2,True)
views.CropBox = vsBB
TransactionManager.Instance.TransactionTaskDone
OUT = vsBB.ToProtoType()
I think my problem has something to do with a poor understanding of the relative location of the view’s origin. I don’t understand why the starting origin is so far from the expected value, and how to modify the origin i use to generate the new transform. It seems like the approach for constructing the transform to set/modify the BoundingBox transform is different than when generating a new SectionView?
here’s my test file. You do need to select the room and the elevation marker independently. There’s a integer slider to switch between the different elevation vews
test_ResetCrop.dyn (184.5 KB)
