Assign 3D View template
Hii guys,
I’ve been searching around and can’t find the right awnser.
the question is: How to assign a view template to a Axonometric view with the revit API
Thnks in advance
Assuming you have the ElementId of the view template, can directly set the target View’s ViewTemplateId property.
# Assume 'view' is your axon view
# Assume 'id' is the ElementId of your template
view.ViewTemplateId = id
Yes that did the trick!
I was on the right track but instead of feeding an ID number, I gave it a string of the ID number which did not go so wel :smile:
Thank u very much, @cgartland
Hello, how do you get the Id of the 3D template?
Thank you
