I’m trying to pull the split gap from our coupling family - in this case 1/16". When I do, Revit pulls the number in feet which is fine, except that instead of 0.00520833… it shows 0.00525. Which is some weird rounding, seems like it should be rounding to 0.00521. However, it is half of 0.063 which is a rounded version of 1/16" in decimal inches (0.0625).
Does this 1/2000" matter? Probably not. I suppose it could add up over time, but I’m not sure what you’d be doing in Revit that many times in a row.
But, apparently it was just enough that happened to notice it when verifying the points were landing where I wanted them to.
I’m very zoomed in here, the gap shown is 1/16" , but in theory those blue dots should be right where those lines cross:
So this is mostly a question out of curiosity, but, does anyone know if there’s a way to control the precision when retrieving a parameter value with .AsDouble()
? I tried changing my Geometry scaling, and project units, but that didn’t do anything.
