Need some help making a script. I’m a little new to dynamo. I made a script that places an areareinforcementsystem (using the Bim4struc package). Like in revit. In Revit you can remove the system en keep the rebars
Question:
How can I remove reinforcementsystem using Dynamo and keep all top and bottom rebars?
Maby with python or…?
clr.AddReference('RevitAPI')
if isinstance(IN[0], list):
elements = UnwrapElement(IN[0])
elements = [UnwrapElement(IN[0])]
for e in elements:
AreaReinforcement.RemoveAreaReinforcementSystem(doc,e)
OUT = 0
Could you please say if it’s possible to get the id of these rebar sets, I need to change some of their parameters after removing the Area reinforcement system, but I don’t know how?
