Area Tag Set TagHeadPosition / setting attributes
Good day!
Python newb here, I am trying to get and set the head position for area tags, but Im having trouble getting any packages to work for area tags. I modified a python script for getting TagHeadPosition but having trouble using it to setting TagHeadPosition. I am familiar with setting parameters with python but how does it differ from setting attributes?
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
if isinstance(IN[0], list):
    tags = UnwrapElement(IN[0])
    tags = [UnwrapElement(IN[0])]
pts = IN[1]
listout =[]
for x in tags:
    y = x.TagHeadPosition
    setattr(x, y, pts)
Hello, I still need a solution for this :slight_smile: . I have made progress and the code seems to work but is not reflecting on Revit itself. Is this a transaction manager issue?
From checking with another custom node the input and output values seem to align, however the changes dont seem to be reflected on Revit:
from Autodesk.Revit.DB import AreaTag
# Get the current Revit document
# Convert Dynamo inputs to Revit elements
    area_tags = [UnwrapElement(tag) for tag in IN[0]]
    area_tags = [UnwrapElement(IN[0])]
# Convert Dynamo points to Revit XYZ points
if isinstance(IN[1], list):
    points = [pt.ToXyz() for pt in IN[1]]
    points = [IN[1].ToXyz()]
# Ensure that the number of points matches the number of area tags
if len(area_tags) != len(points):
raise ValueError("Number of area tags and points do not match.")
# Start a transaction
# Set the TagHeadPosition for each area tag to its corresponding point
for tag, point in zip(area_tags, points):
if isinstance(tag, AreaTag):
        tag.HasLeader = True
        tag.LeaderEndCondition = LeaderEndCondition.Free
        tag.TagHeadPosition = point
# Commit the transaction
# Output the modified area tags
OUT = area_tags
I tested this with Revit 2022, and it seems it is a bug.
If you add a subsequent process in python/dynamo that changes something else in the tag too, you will see it will apply the move. e.g., I changed the Angle property to 1 and back to 0 after running your node.
Thank you Hamid! I appreciate the response! This should work for what I need :slight_smile:
