I actully have a question in regards to a Python script for use through pyRevit. I am not actually sure if this is ok in the Dynamo forum… In case it is a problem, I can recreate the issue in Dynamo
So, what it’s all about: in short, the scrypt lets you select Areas from Area Plan view and creates a separate plan view for each area. In the end, it also takes the Area Bounday and creates a crop region, based on that boundary. Here’s the issue - sometimes Revit creates Areas even though boundaries are drawn incorrectly:
Once you get this boundary afterwards and try to apply it to the crop region, you will get a message of the kind: ‘curves are not contiguous … smth … smth’
My only solution so far is to tell the scrypt not to create Crop Region in this case and to return a list the problematic areas for the user to check their contours. However, it would be amazing if someone knew a workaround for this.
Here’s the Python code:
from Autodesk.Revit.DB import Transaction, Element, BuiltInCategory, BoundingBoxXYZ, View, ViewPlan, DisplayStyle, SpatialElementBoundaryOptions, ViewFamilyType, ViewDrafting, ViewFamily
from Autodesk.Revit.DB import FilteredElementCollector, CurveLoop, XYZ, ViewDetailLevel, BuiltInParameter, BoundarySegment, Curve, BoundarySegment, ElementTransformUtils, Area, Parameter
from Autodesk.Revit.DB import Curve, CurveLoop, DirectShape, ElementId, Line, BoundingBoxXYZ, ViewCropRegionShapeManager, ElementId
from Autodesk.Revit.DB import SolidOptions, GeometryCreationUtilities, Transform, ViewDuplicateOption, TemporaryViewMode
from Autodesk.Revit.DB.Analysis import VectorAtPoint
from rpw import db, ui, doc, uidoc
from pyrevit import forms, revit
import sys
import math
# Create a parameter to point at the current document
uidoc = __revit__.ActiveUIDocument
doc = __revit__.ActiveUIDocument.Document
view = doc.ActiveView
t = Transaction(doc, "FloorPlan From Area")
t1 = Transaction(doc, "Temporary Hide / Isolate")
# Check if the active view has the neccessary parameters set
if(doc.ActiveView.LookupParameter("Phasing").AsString() == None):
print("Please, set value for the parameter 'Phasing' of your active view and try again!")
sys.exit()
# Isolate only Areas in the active view
area_ids = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Areas).WhereElementIsNotElementType().ToElementIds()
t1.Start()
view.IsolateElementsTemporary(area_ids)
t1.Commit()
# Make a selection for desired Areas
selection = revit.get_selection()
selection_list = revit.pick_rectangle()
elements = []
for element in selection_list:
element_id = element.Id
elements.append(doc.GetElement(element_id))
# Filter View Types and set the one to apply to apply to new views
viewfamily_types = FilteredElementCollector(doc).OfClass(ViewFamilyType)
viewfamily_types_list = []
for view_type in viewfamily_types:
if("Plan" in view_type.LookupParameter("Type Name").AsString()):
viewfamily_types_list.append(view_type.LookupParameter("Type Name").AsString())
if("Gross" in view_type.LookupParameter("Type Name").AsString()):
if("Rentable" in view_type.LookupParameter("Type Name").AsString()):
type = forms.SelectFromList.show(viewfamily_types_list,
multiselect = False,
title = "Select View Type to assign:",
button_name = "ASSIGN VIEW TYPE")
if(type == view_type.LookupParameter("Type Name").AsString()):
type_id = view_type.Id
# Filter View Templates and set the one to apply to apply to new views
templates_collector = FilteredElementCollector(doc).OfClass(View).ToElements()
templates_list_name = []
for template in templates_collector:
if(template.IsTemplate == True):
if("Plan" in template.Name):
templates_list_name.append(template.Name)
res = forms.SelectFromList.show(templates_list_name,
title = "Select View Template to assign",
button_name = "ASSIGN TEMPLATE")
if(template.Name == res):
res_id = template.Id
# Input angle of rotation
rotationAngle = forms.ask_for_string(
default="0.00",
prompt="Enter angle of rotation /decimal degrees, direction: counter - clockwise/:",
title="Angle of rotation"
floatAngle = (-float(rotationAngle) * math.pi) / 180
# Input for duplicating the view with detailing
detailing = forms.CommandSwitchWindow.show(
["YES", "NO"],
message="Create new floorplan? 'YES' or 'NO' (duplicate the active view with detailing):"
if detailing == "YES":
noDetailing = True
noDetailing = False
# Create floorplan of selected view type and apply selected view template
newplans = []
rotation_angles = []
areas = []
errorlist = []
t.Start()
for a in elements:
Options = SpatialElementBoundaryOptions()
s = a.GetBoundarySegments(Options)[0][1].GetCurve()
sp1 = s.GetEndPoint(0)
sp2 = s.GetEndPoint(1)
vector = (sp2 - sp1).Normalize()
if noDetailing:
AreaPlan = ViewPlan.Create(doc, type_id, a.LevelId)
AreaPlan = doc.GetElement(doc.ActiveView.Duplicate(ViewDuplicateOption.WithDetailing))
AreaPlan.DisableTemporaryViewMode(TemporaryViewMode.TemporaryHideIsolate)
AreaPlan.CropBoxActive = False
AreaPlan.ViewTemplateId = ElementId(-1)
AreaPlan.LookupParameter("IPA View Sub Group").Set("400")
AreaPlan.LookupParameter("Phasing").Set(doc.ActiveView.LookupParameter("Phasing").AsString())
AreaPlan.ViewTemplateId = res_id
active_view_name = view.Name.ToString()
a_crop = []
area_segments = a.GetBoundarySegments(Options)
for area_segment in area_segments[0]:
p1 = area_segment.GetCurve().GetEndPoint(0)
p2 = area_segment.GetCurve().GetEndPoint(1)
a_crop.append(Line.CreateBound(p1, p2))
try:
AreaPlan.CropBoxActive = True
AreaPlan.GetCropRegionShapeManager().SetCropShape(CurveLoop.Create(a_crop))
except:
errorlist.append(a.Id)
newplans.append(AreaPlan)
areas.append(a)
try:
AreaPlan.Name = active_view_name + "PC" + "-" + a.Number.ToString()
except:
AreaPlan.Name = active_view_name + "PC" + "-" + a.Number.ToString() + ".01"
t.Commit()
# rotate floorplans if rotation angle is set
if(floatAngle != math.radians(0)):
for counter, plan in enumerate(newplans):
area = areas[counter]
new_crop = []
# Transactions for the purpose of obtaining and rotating the crop region
temp1 = Transaction(doc, "Hide crop region")
temp2 = Transaction(doc, "Unhide crop region")
temp3 = Transaction(doc, "Rotate crop region")
temp4 = Transaction(doc, "Create new crop region offset")
temp1.Start()
plan.CropBoxVisible = False
temp1.Commit()
all_in_view_crop_hidden = FilteredElementCollector(doc, plan.Id).ToElementIds()
temp2.Start()
plan.CropBoxVisible = True
temp2.Commit()
cropId = FilteredElementCollector(doc, plan.Id).Excluding(all_in_view_crop_hidden).ToElementIds()
bbox = plan.CropBox
center = 0.5 * (bbox.Min + bbox.Max)
axis = Line.CreateBound(center, center + XYZ.BasisZ)
temp3.Start()
ElementTransformUtils.RotateElement(doc, cropId[0], axis, floatAngle)
temp3.Commit()
Options_new = SpatialElementBoundaryOptions()
segments = area.GetBoundarySegments(Options_new)
for segment in segments[0]:
pt1 = segment.GetCurve().GetEndPoint(0)
pt2 = segment.GetCurve().GetEndPoint(1)
new_crop.append(Line.CreateBound(pt1, pt2))
temp4.Start()
try:
plan.GetCropRegionShapeManager().SetCropShape(CurveLoop.Create(new_crop))
except:
pass
temp4.Commit()
# disable temporary hide isolate mode of the active view
t1.Start()
view.DisableTemporaryViewMode(TemporaryViewMode.TemporaryHideIsolate)
t1.Commit()
if errorlist != []:
print("The following Areas were found to have problematic contours, thus their floorplan views do not have Crop Region applied. You could check those areas' contours by their ids:\n\n {}".format(errorlist))
print("All area plans were created successfully!")
Here’s also a basic sample file, where it can be tested directly:
Test_detached.rvt (2.9 MB)
And the python for a direct download:
FloorPlanFromAreaRentable_script.py (7.9 KB)
Cheers!
