I have a question regarding whether Civil 3D Dynamo can be utilized to insert and export Excel files for editing or updating the ‘Extended Data’ associated with Civil 3D objects. Traditionally, we would place text with different objects for editing purposes. Can we use Dynamo to place text that follows the naming conventions of pipes or structures for this editing process?
Thank You!
I’m not 100% sure what your goal is, but generally the answer is yes, there are nodes available for reading/writing Excel data and also updating property set information.
It works fine to deal with properties in extended data without using excel but ifrån you have a excel with data for a specific Structure in a specific Pipe network it would be possible to get information from the excel as well.
