Apply function to list regardless of levels in python
I found this answer by @Konrad_K_Sobon on SO about how to make a python script handle different list structures, but for some reason it’s not working on a different function and I can’t figure out why. I guess it’s the unwrapping that’s causing problems.
I’m getting AttributeError: ‘List[object]’ object has no attribute ‘ViewType’. It’s not supposed to call the passed function on the object if it’s a list, but it seems it’s not recognizing this unwrapped List[object]. How can I get around this?
clr.AddReference("RevitAPI")
views = UnwrapElement(IN[0])
def ProcessList(_func, _list):
    return map( lambda x: ProcessList(_func, x) if type(x)==list else _func(x), _list )
def getViewType(view):
	return view.ViewType
if isinstance (views, list):
    outlist = ProcessList(getViewType, views)
    outlist = getViewType(views)
OUT = outlist
How about handling any list structure:
#Function to handle any list structure
ProcessLists = lambda function, lists: [ProcessLists(function, item) if isinstance(item, list) else function(item) for item in lists]
ApplyFunction = lambda func, objs: ProcessLists(func, objs) if isinstance(objs, list) else [func(objs)]
#Funtion to unwrap
def Unwrap(item):
    return UnwrapElement(item)
if isinstance(IN[0], list):
	views = ProcessLists(Unwrap, IN[0])
	views = Unwrap(IN[0])
#Define function to get view type
#OUTPUT
OUT = ApplyFunction(getViewType,views)
That definitely has a much better ring to it :smile: and you didn’t fail to deliver
Thanks Kulkul! Could you maybe let me know why we need the
line here? I’m still trying to wrap my head around how it all actually works.
This would be good start for you:
Oh I did learn about lambdas just a few days ago, but I couldn’t figure out how exactly you’re using it in this case. I guess I’ll just have to dissect your code more closely to understand when I have some time.
