Amount daylight
Measuring the amount of daylight entering the space
In the interest of maintaining the blunt theme.
Grasshopper
Honeybee
Hi .
I now should use of Honeybee but I try do in dynamo its my challenge.
by dynamo plugins…
As far as I know, beyond Autodesk Insight daylighting is not typically undertaken using dynamo. Happy for someone to mention if it is though.
I find some plugins: (solar, TASmanianDevil BIM,Topology energy) …
May please check theirs plugins ?
Yes, you may check them.
I highly doubt any of them are up to the challenge of daylight analysis given how complex it is in Grasshopper itself using Ladybug. You have my advice - if you wish to try Dynamo instead then it’s time for you to experiment.
Thanks.
Hello GavinCrump
Are you see my work on day light analize?
Is that a daylight study? It looks like sunlight.
Hello GavinCrump
I got the amount “HourlyDiffuseRad"and"GetHourlyDirectRad”
Sorry for being an archaeologist and digging up this topic but : did anyone here found a good tool for Revit to produce direct sunlight analysis in minutes?
I see that Autodesk Insight plugin for Revit has exactly what I would be interested in - but it shows sun energy in kWh - and there is no way to change it to just minutes.
If you’ve got Rhino on hand, give Rhino Inside a spin. For architects and most engineers in my country this is accepted industry best in show.
I also built a slower/less flexible workflow in Dynamo:
