In this case we have list with all elements equal False, to simplify next step I used replacement from “” to “false” (without “” is not string)
In next step I try to define bool because whole list is constain of the false
And that’s what comes up
Is it the reason, can I use other function to achive same results?
What results do you get from a List.UniqueItems node?
Sory, I found mistake in my script, do you know how to delete this post?
Rather than delete it, it would be better for you to post what you found in case someone else has a similar issue.
Problem was in one of my custom nodes, I had to check all of them and in one i used | “false” | instead
| false |, it was a reason.
