Alignment.ByPoints works as a node but fails from Python Script — what am I missing?
import sys
import System
from System import Array   # para criar arrays .NET
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
import Autodesk.AutoCAD.DynamoNodes as Auto
import Autodesk.Civil.DynamoNodes as Civil
import CADNodes.Civil3D as CADN
# Import references from Dynamo
dataEnteringNode = IN
polyCadList = IN[0]
surface = IN[1]
surfaceOffset = IN[2]
pipeNetworkSelected = IN[3]
partListNameSelected = IN[4]
partSizeNameSelected = IN[5]
insertPoint = IN[6]
alignList = []
for i, polyCad in enumerate(polyCadList):
    lineList = []
    for line in polyCad.Geometry.Curves():
        try:
            startElevation = Civil.Surface.ElevationAtXY(surface, line.StartPoint.X, line.StartPoint.Y)
        except:
            startElevation = 0
        try:
            endElevation = Civil.Surface.ElevationAtXY(surface, line.EndPoint.X, line.EndPoint.Y)
        except:
            endElevation = 0
        obj = {
            "Curve": line,
            "Start": startElevation - surfaceOffset,
            "End": endElevation - surfaceOffset
        lineList.append(obj)
    item = {
        "PolyCurve": polyCad.Geometry,
        "AlignName": "Alignment_" + partSizeNameSelected + " - " + str(i),
        "ProfileName": "PRF_" + partSizeNameSelected + " - " + str(i),
        "PipeInfoList": lineList
    alignList.append(item)
for objectList in alignList:
    linelist = objectList["PipeInfoList"]
    for i, item in enumerate(linelist):
        if item["Start"] == 0:
            # look backwards
            for j in range(1, i):
                if linelist[i-j]["End"] != 0:
                    item["Start"] = linelist[i-j]["End"]
                    break
                if linelist[i-j]["Start"] != 0:
                    item["Start"] = linelist[i-j]["Start"]
                    break
        if item["End"] == 0:
            # look forwards
                if linelist[i+j]["Start"] != 0:
                    item["End"] = linelist[i+j]["Start"]
                    break
                if linelist[i+j]["End"] != 0:
                    item["End"] = linelist[i-j]["End"]
                    break
alignments = []
accumulator = 0
for i, alignObj in enumerate(alignList):
    #Alignment Creation
    pts = alignObj["PolyCurve"].Points
    alignName = "Alignment_" + partSizeNameSelected + " - " + str(i)
    alignType = "Centerline"
    align = Civil.Alignment.ByPoints(alignObj["PolyCurve"], alignName, 0, alignType, "")
OUT = [alignList, alignments]
I’m trying to create an Alignment from a Python Script node by calling Autodesk.Civil.DynamoNodes.Alignment.ByPoints.
With the exact same inputs, the Alignment.ByPoints node works, but calling it from Python throws a “No method matches given arguments” error.
If you go to the Help documentation for the Alignment.ByPoints node (right-click > Help…) you should see a section for Inputs and Outputs that describes each of the inputs and their required types. Make sure those types match the object types you’re providing in Python.
Alignment.ByPoints need a .Net List<DesignScript.Geometry.Point> as parameter
static ByPoints(System.Collections.Generic.List1[Autodesk.DesignScript.Geometry.Point], System.String, Double, System.String, System.String) → Autodesk.Civil.DynamoNodes.Alignment
try this
import System
#import net library
from System.Collections.Generic import List, IList, Dictionary, HashSet
                    List[DS.Point](alignObj["PolyCurve"].Points),
                    alignName,
                    0.0,
                    alignType,
import sys
pt1 = DS.Point.ByCoordinates(0, 0)
pt2 = DS.Point.ByCoordinates(50, 0)
pt3 = DS.Point.ByCoordinates(100, 0)
pts = [pt1, pt2, pt3]
alignName = "test"
align = Civil.Alignment.ByPoints(List[DS.Point](pts), alignName, 0.0, alignType, "")
OUT = align
How can I import the List class?
I update my previous post
add / replace this at the top
import sys
import System
#import net library
Thanks a lot. It’s now working perfectly.
