Align beams to reference lines
Good morning.
Can any Revit API method let me align beams to reference lines in order?
Because I want to relocate beams to new position with all previous information.
So far, I have studied a function , PostCommmand, Which can allow me to use the ‘Align’ Command in Revit, But, it is not totally automatically since I need to select elements in Revit view.
P.S. Reference I studied about PostCommand
Therefore, I am wondering that whether having a function or workflow can allow me input target reference lines and beam elements, then do a for loop, so I can automatically align and relocate beams to where what I want in order.
Any help is greatly appreciated. Thank you in advance.
You can use the OOTB Element.SetLocation node or one of the 3rd party equivalents.
Ah, I see you want an API method. You can get the Location of the element with element.Location which will give you a LocationCurve object and then you can set the LocationCurve.Curve with a curve of your choice.
@hctungBHP7B something like this will work:
If you want to align the middle of the beam to the lines using the Revit API, it is as easy as @Daniel_Woodcock1 mentioned, but if you want to align to the outer or inner face of the beams, I guess it is easier to go by Dynamo nodes.
Hi @Elie.Trad,
I passed by this post earlier and thought if this could apply for Lines to align to middle of Wall instead?
Hope i’m not too late! :face_with_open_eyes_and_hand_over_mouth:
Cheers!
@Ec_loh
@Ec_loh it should work with a little bit of tweaking.
