Returning once again with a solution!
@JustinStirling found a discussion found here which clued us into a BimorphNodes node called LinkElement.OfCategory , which seemed to appropriately pick up on the architectural link’s ceilings, and allowed us to host our diffusers to the ceiling! We tested it out a couple times and were successful: if the ceiling moves in the arch model, it moves in our model!
So I created a quick user interface for our engineers to be able to determine which Supply and Return diffusers to use. The code then takes these diffusers and places one of each in the middle of the room, hosted to the ceiling.
My next step will be to work with the awesome Sparrow package to align it to the ceiling grid (if there is one).
Thank you all that helped get us to this point!
Diffuser UI SIMPLIFIED 4.dyn (159.6 KB)
