Dears,
Is it possible while adding two values to single cell of excel bellow each other?
And is it possible to make one of them bold and other standard. See picture bellow:
I believe that two values separated by a carriage return is possible. Insert a carriage return in the string before you write the data to excel.
In a code block try typing:
A+"
"+B;
If that doesn’t work use a string node with just the return in it.
Not sure about the building of the text.
Thanks a lot Jacob. It worked great.
