Hi Folks,
I am a lost. I want a simple graph there are adding the 2 list together. The “watch” list index 0 should be in the list index 0. How can I add them together were they are under the same index ?
I hope you can help …
/Karsten
Flatten node is to much… i just want to a some new values in the list at the same lacing.
Therefore L1 in the list, i want to add values.
Do you have a good graph for that ?
Is List.Transpose not getting you what you need? It might be more helpful if you could show us what your expected outcome would look like.
Hey @kamuYAGW8 ,
You need to chop the first list with List.Chop (with 1), because you need to split your main list into multiple
After that you can use List.additemtofront/end or List.combine
