Add Selection Filters to views
Hello all,
I am trying to add a Selection Filter to a list of views. When I pass a Parameter Filter to View.SetFilterOverrides everything works great. If I change nothing but give it a single Selection Filter it gives me this “Warning: One or more of the input types are not matching. Couldn’t find a version of SetFilterOverrides that takes arguments of type (__array,__array,__array,__array)”
Do any of you know anything about this or know a work around?
Thanks,
It seems this node doesn’t appear to accept SelectionFilterElements anyway:
API Docs show they are two separate classes, but both fall under FilterElement Class:
ParameterFilterElement Class
SelectionFilterElement Class
Should be able to do it with a Python script using the SetFilterOverrides Method, or maybe there is a package out there that has a node for this already that I’m unaware of :slight_smile:
@awilliams is correct that this node doesn’t accept Selection Filters. I posted a request to GitHub so that the devs are aware of your wish:
Cheers!
Hi, have you successfully done want you want ?
I’m interested to know how you did it and how you get all your selection Filter in current document.
Thank you.
Hi, I am very interesting too. How to Selection filter as a view filter ?
Please :slight_smile:
hello @baud.dem
When you create a Selection-Based Filter this automatically creates a filter
then, there is an example to Add a Selection-Based Filter to a view Template
Your code works very fine danke. I was also working on a code but it has a color issue that I couldn’t yet solve. Good idea to use the templates ! Bravo.
We agree that it doesnt work for a view without template ? :slight_smile:
yes (for this Python script)
