I want to add Profile Labels to Lines of multiple Profiles in multiple Profile Views.
Specifically, I want to add the “Standard” Profile Tangent Label Style so that the gradients are displayed.
The result will be something like this:
A standard Civil 3D workflow:
- Select a Profile View
- Click Edit Profile Labels in the ribbon menu
- Select a Profile in the Profile View
- In Profile Labels window, choose Lines from the Type dropdown menu
- Choose Standard from the Profile Tangent Label Style dropdown menu
- Click on Add button
- Click Apply or OK
I have found the Profile Line Label Styles node in the Camber package, but I do not know how to apply it. It does not seem to work with CivilObject.SetStyle node, which is the workflow I use for setting the style of the Profile View.
Is there a node to set styles or add labels, or do I need to use a Python Script node?
Any help would be appreciated. Thanks!
Civil3D_ProfileLineAddLabel.dyn (8.7 KB)
Yep, that will be tricky as there is no node for that AFAIK. There are tons of labeling nodes OOTB and in Camber, but not for Profiles tho.
last time i used this with style names hardcoded in the script:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.Civil.DatabaseServices.Styles import *
# Inputs
profileView = IN[0]
profiles = IN[1]
styleName = IN[2]
dataEnteringNode = IN
editor = adoc.Editor
civDoc = CivilApplication.ActiveDocument
with adoc.LockDocument():
with adoc.Database as db:
linestyle = civDoc.Styles.LabelStyles.ProfileLabelStyles.LineLabelStyles["UNI_árok description"]
PVIstyle = civDoc.Styles.LabelStyles.ProfileLabelStyles.GradeBreakLabelStyles["UNI_A_árok_felirat_szelvény_magasság"]
lineLabelStyle = t.GetObject(linestyle,OpenMode.ForWrite)
lineLabelStyle = t.GetObject(PVIstyle,OpenMode.ForWrite)
for profile in profiles:
ProfileLineLabelGroup.Create(profileView.InternalObjectId,profile.InternalObjectId,linestyle)
ProfilePVILabelGroup.Create(profileView.InternalObjectId,profile.InternalObjectId,PVIstyle)
t.Commit()
pass
OUT = lineLabelStyle, lineLabelStyle
You’ll want to use the Label.SetLabelStyle node for setting label styles, not CivilObject.SetStyle.
