Thanks for your reply, and I think I am partly there.
I have managed to produce the following code, which returns false and doesn’t add the category to the parameter:
import Autodesk.DesignScript.Geometry
# Import Element wrapper extension methods
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
from System import Array
sys.path.append(pyt_path)
#categories to add to parameter
cat1 = UnwrapElement(IN[0])
cat2 = UnwrapElement(IN[1])
#Parameter name
param = "test"
iter = doc.ParameterBindings.ForwardIterator()
setCat = None
categorySet = doc.Application.Create.NewCategorySet()
categorySet.Insert(cat1)
categorySet.Insert(cat2)
out=0
while iter.MoveNext():
definition = iter.Key
elemBind = iter.Current
if definition.Name == param:
out = elemBind.GetType()
instanceBinding = doc.Application.Create.NewInstanceBinding(categorySet)
setCat = doc.ParameterBindings.ReInsert(definition, instanceBinding,BuiltInParameterGroup.PG_TEXT)
OUT = setCat
