Below I made a python script for the Rooms. Basically I want to do what Element.Parameters function is doing. I tried using a python scrtip like this but no use
I need to access all of the Parameter types from the main class or object. Because I will need all of them in the python script to make some comparing to each other and change values
Because I need to access it’s properties in the python script as I said. I was thinking
it should be like these but I couldnt figure it out.
Element.Parameters(‘foo’)
Element.Properties.Schedule(‘foobar’)
Element.Parameters.Properties(‘bar’)
