Access the Dynamo MCP Server in Your Own AI
The problem
As of Dynamo 4.2, the Dynamo MCP Server is out, but it only surfaces in Autodesk Assistant. A lot of you already have an AI tool you like and use every day, and right now you can’t point it at Dynamo.
What we’re considering
Opening up the Dynamo MCP Server so you can connect it to the AI of your choice (Claude, ChatGPT, Copilot, Cursor, a local model, whatever you use). Same server, same capabilities, just reachable from outside Autodesk Assistant.
Concept image, not final UI.
This one is purely under consideration. No timeline, no commitment, and honestly we need your input before we decide if and how to do it.
How you can help
  • Which AI do you use day to day, and why that one?
  • Is it a desktop app, an IDE, a CLI, or something you run locally?
  • What would you actually do with it once it’s connected to Dynamo?
  • Does your company limit which AI tools you’re allowed to use? If so, which ones are approved?
  • What guardrails would you want before an outside AI can build or run graphs in your model?
Reply below or vote if this matters to you. Even a one-liner like “Claude Desktop, because that’s what I already use” is helpful.
Related
Safe harbor statement
Roadmaps are plans, not promises. We’re as excited as you to see new functionality make it into the products, but the development, releases, and timing of any features or functionality remain at Autodesk’s sole discretion. These roadmap updates should not be used to make purchasing decisions.
