I am trying to access to some information of a linked files. I can access to the file instance by filtering the OST_RvtLink in python:
collector = FilteredElementCollector(doc)
collector.OfCategory(BuiltInCategory.OST_RvtLinks).WhereElementIsNotElementType()
famtypeiterator = collector.GetElementIdIterator()
famtypeiterator .Reset()
instances =
for i in famtypeiterator:
insti = doc.GetElement(i)
instances .append(insti)
OUT = instances
but after this I cannot use the links as revit documents and pass that information to another filter in order to schedule elements.
If I use some definitions, such as SteamNodes from JBenoit (https://aecuandme.wordpress.com/) and I try to access to all the revit.documents using:
<span style=“color: #75715e;”>x = Dynamo.Utilities.dynRevitSettings.Revit.Application.Documents</span>
from (AEC, you and me.: Image)
I get this error:
Warning: IronPythonEvaluator.
<wbr />EvaluateIronPythonScript operation failed. Traceback (most recent call last): File "<string>", line 54, in <module> AttributeError: attribute 'dynRevtiSettings' of 'namespace#' object is read-only
Any clue to solve this?
Many Thanks!!!
